Re: Mode Schedule
Dave, many thanks for your comprehensive reply! Will set things up as you have suggested and see how things go.
Re: Mode Schedule
Dave have entered data as you suggested (after watching the video), but no success! I refreshed the page etc etc, but still get the message "Parametersdo not meet expectations"
I used
mode 1: 02.00 -04.59. Force charge, Min SOC 10%, Max SOC 100%, FDSOC 100%, FDPWR 5000
mode 2: self use, Min SOC10%, Max SOC100%, FDSOC10%, FDPWR 5000
Mode 3: force discharge, minSOC10%, MaxSOC100%, FDSOC 30%, FDPWR 3000
Cant see where I have gone wrong!
Re: Mode Schedule
What is your normal minSoC set to, is that 10%?, if not can you change it to 10% as it won’t let you set the scheduler minSoC (on grid) to be lower than it.
Re: Mode Schedule
My min SOC is set to 10%.
I have now tried to set just the two modes (forced discharge and forced charge) as the video indicates that at all other times the battery works in self use mode.
But no luck!
Re: Mode Schedule
As it’s not behaving just need to ask a few questions which might narrow this down.
Have you used the scheduler before successfully or is this the first time?
Can you set a simple schedule something like 15:00-16:00 Self use, minsoc 10%, maxsoc 100%, FDSoc 10%, FDPwr 0 - save that and see if it accepts those parameters.
Have you ever tried to set the Octopus ‘agile’ connection up in the app (it overrides scheduler)
Can you post your firmware versions and i’ll check to make sure they are up to date - open the app, click on ‘Device’, then click the serial number below the inverter picture and it will list a number of items, the firmware i’m interested in is Master, Slave and ARM versions.
What size (model) is your inverter (3.7, 6, 7 etc..)
Re: Mode Schedule
Dave, thank you for your continuimg patience and help!
No, I have not used the scheduler before. Until a few days ago when I found the Community forum I had no idea what to do to set up periods for discharging and recharging the battery as appropriate for the Octopus Flux tariff I joined when the panels and battery were installed!
I have seen the Octopus Agile option in the app, but am on the Flux tariff.
I have attempted to set up a simple mode as you suggested. Still get the refusal!
Firmware versions are as follows:
Master 9.42
Slave. 1.00
Version manager. 0.50
Version_BCU 1.001
Version_AFCI. --
No ARM version shows on my app.
I have not found any means of updating firmware within the app.
All I can tell you about the inverter (which is built in with the battery) is that the combined unit is an EVO 10-5-H, which I think means that the inverter is nominally 5kW.
I have emailed Fox to ask them whether they have any suggestions - no offence meant to you.
Re: Mode Schedule
timjwc wrote: Wed Oct 22, 2025 7:01 pm Dave, thank you for your continuimg patience and help!
Master 9.42
Slave. 1.00
Version_BCU 1.001
Version_AFCI. --
Ok thanks for all of that, it sounds like the 5kW version and no offence taken - the Evo is a relatively new product so this is very new to both of us :)
This isn’t scheduler ‘normal’ operation and given it won’t let you set even the simplest schedule I think this may well be a firmware related issue, you can’t update the firmware yourself, that must be done by an installer or Fox themselves so I lets see what Fox come back with - they are usually quick to reply.
Re: Mode Schedule
Dave, I have provided serial numbers and firmware data to Fox and await their comments after they remotely test things!
Re: Mode Schedule
Fox has updated my firmware to:
Master. 1.02
Slave. 1.00
Version Mgr. 1.05
Version BCU. 1.001
I have now been able to set up schedules using the feature in System Settings/Tariff. I have also been able to set up the same schedules in Quick Settings, but cannot achieve the disabling of Mode Scheduler.
So I do now appear to be exporting power during the hours of 16.00 to 19.00, and should import power between 2am and 5am.
No luck with configuring the EV charger; I receive the message that it is done but will take a minute - but that does not register!
Part way there! Will continue to converse with Fox.
Re: Mode Schedule
Good to hear, thanks for the feedback, usually when your firmware has a 9. prefix as your master did it means that it is a development release so those versions sound much better - fingers crossed :)
