Hi, when I use mode scheduler as below force discharge works but force charge doesn't.
The only way I can get it to work is to use force charge via charging time window, and force discharge via mode scheduler, turning one on and the other off.
How do I get both to work via mode scheduler?
1 x KH8 hybrid inverter
3 x EQ4800 batteries (13.98kWh)
20 x 440w panels
EV household
20 x 440w panels
EV household
Your first picture is for Grid Charge, so this only has brute force of charging the battery... so turn that off and use the manual scheduler options so you take more control of your system.
In your second picture it *looks* right, but you are saying it doesn't charge when you manually set it like that?
I would say that either your app is out of date, or your firmware in your inverter is. As it should have Min SOC%, Max SOC%, FC SOC% & FC Pwr W.
In your App, press Device at bottom, find Inverter and click on this, then you should see picture of Inverter and below this, the serial number, click on the serial number and you will see "About Device" at the bottom you will see Versions (Master / Slave / Manager) please post the values or a screenshot.
Look here and compare
viewtopic.php?p=8069#p8069
KH Latest
Master: 1.55
Slave: 1.02
Manager: 1.54
KH Latest
Master: 1.55
Slave: 1.02
Manager: 1.54
Thanks for the response. The manual scheduler still doesn't work when turning the Grid Charge off.
My app is up-to-date. Looks like my firmware is old (see below), I'll get this updated.
KH
Master: 1.27
Slave: 1.01
Manager: 1.19
KH
Master: 1.27
Slave: 1.01
Manager: 1.19
20 x 440w panels
EV household
20 x 440w panels
EV household
Yeah might be an idea to see if they will do the Battery pack at the same time if that needs doing.
Best of luck, hopefully this sorts out your problem.
I updated the inverter and battery firmware, and it seems to work fine now. Thanks for the help!
20 x 440w panels
EV household
20 x 440w panels
EV household
