Is anyone seeing, this issue, it’s been there for a number of app and fw versions.
PV producing way more than you see when looking at inverter stats.
Not sure if it’s an app display fault, or inverter reporting fault
The Fox app showing 1.148kW of PV Power is a cloud snapshot (4mins old in the picture)
This is next to the myenergi app showing 3.8kW.
The FoxCloud2.0 App will show you at this location the 5min average, if you waited 1 more minute that value would change of course.
The other picture showing the 5s refresh rate FoxCloud2.0 app against the myenergi app, this is not that far off and could be drifting depending on how close to realtime both return to you. I have the myenergi app too, it is within a little bit of the App give or take, depending on when the snapshot is taken.
On another note, you can see in the 5sec refresh rate some really good PV spikes that are really good when clouds go past. When you look back at the 5min cloud data, the PV values are lower as they are averaged out. For example a decent 5.5kW spike in PV after a cloud passes, but when you look at the 5min picture in the cloud it shows 4.2kW for the long term data.
