Re: Non-Compliant FoxESS installations? (Australia)
Yes there is the air gap required underneath.
Mainly as I have a metal cover I designed to protect the battery from rain, sun, muck etc. and in the mistaken hope this would protect the battery from the cold of winter.
When that failed and the internal battery heater couldn’t cope either, I went to the 50mm insulation over the top of it.
As for cell temps I’ve kept a very close check throughout this summer as we have had record heat here.
Surprisingly even when the external air temp hit 39C the max cell temp was 35.8C and min was 31.4C.
As a check I removed the covers for a day and the max temp rose to over 40C, so it appeared to validate that the insulation was working both ways. Conversely, when the external temp dropped to -10C in the winter, the battery maintained a min cell temp of 15C, so the heater never kicked in after the addition of the insulation.
So in the UK the cover can stay on all year, which has really surprised me.
My mate got me to do the same for his EP11 and has had the same results.
The only issue this summer was the inverter overheating and whistling like a kettle, so I’ve installed a couple of 5V USB powered 8” PC fans and that solved the issue.
They will be coming out in the next few days as autumn is arriving and temps are back to normal.
Picture of the battery and inverter covers, with the requested air gaps all round and the fans, built on a couple of wood blocks and it just moves air over the inverter cooling fins, that’s enough to cool the inverter components even if it’s hot air your moving around, it’s a trick we used to use in the early days of servers overheating in data centres that didn’t having enough AC.
As I say, it looks good and great to hear it's working well.
A word of caution though, this is verbatim from the EP11 datasheet:
"Make sure to leave a space of at least 300 mm. A clearance of at least 300 mm must be Ieft around the battery pack for proper cooling. Note: Make sure that the battery pack is always exposed to the ambient air. The battery pack is cooled by
natural convection. If the battery pack is entirely or partially covered or shielded, it may cause the battery pack to stop operating."
It also outlines exceptions to the warranty, including lack of ventilation and failure to adhere with installation warnings.
I don't want to be that guy, but I'd rather you were aware of all the facts when modifying your installation.
https://au.fox-ess.com/Public/Uploads/u ... 250815.pdf
EP11-H battery | BMS vers. 1.009
KH10 Inverter | Master: 1.60 | Slave: 1.02 | ARM: 1.58
W6 WiFi Datalogger v. 1.11
14 x 460W (6.44 kWp) Aiko Neostar 2S solar panels
7 kW Zappi v 2.1 EV charger
TBH when you read the UK install guide and manual, just about every situation known to man is covered as an exclusion to the warranty, even laughably for a unit that’s designed to be outside…… no rain, no sun, no snow, no cool air, not even cold air but cool air !
Jeez is there anything left the environment could throw at it?
Compared to a hot loft area or garage, I’ll take my chances with the way I have it.
If s**t happens, then it happens, I’m more worried about the footie scores than a battery on the blink 👍🤣
In the UK & AU manuals...
'Do not install the battery near water sources or places where the battery can get wet.' :lol:
As @CDubbs mentioned, just about everything is excluded for warranty when it comes down to it.
