Strange Battery Behaviour
Participated in an Axle grid event last night which discharged my battery to the 10% min soc.
By this morning the battery had dropped to 5%.
Once solar started to be generated, 100% of my solar went into charging the battery and 100% of my home use came from the grid.
I thought this must be a quirk of the battery being below 10% but on checking the battery later (when at 16%) I noticed this was still occurring.
I thought I'd try and force the state to end by setting my max soc at 17%. Sure enough when 17% soc was achieved, the battery stopped charging but solar generation went to 0 and 100% of home use was still coming from the grid.
On returning the max soc back to 100% the problem resumed where it left off i.e. 100% solar generation going to battery, 100% of home use coming from grid.
How do I get the battery to start being used by the home again?
Re: Strange Battery Behaviour
Just uploaded a screenshot to summarise the behaviour
What occurs if you switch work modes?
If this does not change things, you may have to restart your system.
I've done both of those to no avail.
I have a g100 state 3 message on the inverter that won't go away. I've contacted my installer who after walking me through a reboot (again) has advised me that Fox need to reset this error remotely as he doesn't have access to the settings required so now I need to wait for him to contact Fox and Fox to action it.
At least I'll probably have a full battery at the end even if my Axle event proves to be cost neutral.
All up and running correctly now which leads me onto this question.
If operators and installers cannot access this menu setting to fix the problem, what happens if Fox go bust. Would that leave me with a system that doesn't work with no way of fixing it.
More likely though is my installer packs up their business (having made a tidy profit out of installations) and Fox won't deal with me directly because my installer has informed me should this occur again, I still need to go through him.
It does beg the question as to why Fox would want to get involved in day to day maintenance though.
There is a factory reset menu IIRC, odds are this would get you working again if there was a duff setting.
TBF, Fox have been around for a fair while, though with any kit, there's always a chance they go belly up, or any other company too.
If you go into your inverter settings at the front panel, there is an on-line menu option that has a G100 sub-menu and you can reset the error there.
I did google the error and attempt to fix it as per the response but I couldn't locate the menu item although the answer I saw only told me to locate the g100 sub menu in settings with no mention of the online menu option. I'll take another look in the morning but if I can reset it, it begs the question as to why my installer said he would need to contact Fox as that menu item was hidden from him.
I assumed it was a feature that fox had removed access to and I was looking at an old method of fixing it.
Just to confirm as per Dave's suggestion, I did locate the G100 sub menu under settings-on grid-g100 para and there is a reset option within it. Hopefully now I know where it is, I'll never need to use it.
Not being quite sure what caused this my installer suggested not discharging to 10% so I contacted Axle to be informed that they have no setting for this and their schedule overrides any minimum SOC set up by the end user stopping at a manufacturers safe level.
Their solution is to adjust the discharge levels in order to not fully drain the battery.
For the past couple of days (I think since this lock up issue occurred but cannot be 100% certain) I get a 40004 loading error when entering the dashboard on a pc.
It only remains for about half a second, then disappears. Data seems to be reading correctly and I can set up schedules which also seem to work OK.
Presumably because the message only appears briefly, whatever communication error it sees is correcting itself within that time. Is that assumption correct as everything appears to be behaving normally otherwise.
Last night there was another Axle event and my battery discharged to 10% but on checking the PC dashboard it said 0%.
This panicked me a bit so I carried out a forced charge. The dashboard then refreshed and showed 14% so I stopped the forced charge. Looking at the history, the battery had never dropped below 10% so was just a display glitch.
The issue was that at this point the household continued to be supplied from the grid, not the battery. The battery state was standby according to the app.
I carried out a reboot of the system and after this the home was supplied from the battery until 10% soc at which point it was 100% grid. The battery state was still stand by.
This morning on waking the battery was being charged by the solar and was at 13%. Battery state = Charging. I then boiled the kettle (3KW/h) and apart from the few hundred KW being generated from solar, it was 100% being supplied from the grid, not the battery.
I won't properly know if this continues until such a point that we want more power for the home than solar is generating because at the moment the battery is charging but my question is is there a minimum that the battery needs to achieve after hitting 10% before it becomes active/useable again?
If not is there a reason why it wasn't being used last night (until a reboot) and wasn't this morning for the kettle despite the battery being above minimum soc?
Well the battery behaved as expected later in the day i.e. drawing load from battery rather than grid. There must be a swing point that needs to be reached once min soc is reached before battery will start discharging to home again (which must be greater than 13%) despite a quick google of the question stating there isn't. :?
Just logged in to Axle to setup a discharge rate for tonight and noticed they now have a "Self dispatch" setting where I can now setup the forced discharge myself through the app. I will give that a go tonight using a min soc of 15%
My installer got back to me today regarding a couple of the issues I mentioned in this thread.
Firstly they've now disabled the G100 setting as it is not relevant to me as I'm on G99. I actually had a second error last week hence the need to contact the installer. They also confirmed to me (what someone had mentioned on another thread) that you can only reset this 3 times. After that Fox need to get involved.
I also asked about a "bounce back" value that the battery needs to reach post achieving 10%. They confirmed that the battery needs to reach 15-17% before normal behaviour returns.
