Foxess 4800 L9 Battery or BMS issue
I have a FoxESS EQ4800 L9 battery with 98% SOH, a reported maximum capacity of 41.09 kWh, and a KH10 inverter.
I’m seeing what appears to be an 18.8% energy loss when discharging the battery from 100% down to 20%.
Discharge figures:
  • Battery capacity: 41.09 kWh
    Energy remaining at 20% SOC: 8.22 kWh
    Expected energy discharged: 41.09 − 8.22 = 32.87 kWh
    Actual energy delivered: 26.70 kWh
    Energy difference/loss: 32.87 − 26.70 = 6.17 kWh
This means I’m seeing a difference of approximately 6.17 kWh, which is around 18.8% of the expected usable energy.
When charging to 100% auto gain ~4 kWh:
I’ve also noticed something similar when charging.
When charging from 20% SOC (8.22 kWh) to 100% (41.09 kWh), I would expect approximately 32.87 kWh of energy to be required.
However, the system only records around 28.80 kWh of energy used for charging to 100%.
Based on this, I suspect that around 2.2 kWh could be normal charging/discharging efficiency losses, while the remaining ~4 kWh may be related to the BMS, SOC calibration, or potentially a battery fault.
I have already tried discharging the battery down to 10% SOC and then slowly charging it above 80% at around 1–2 kW, but this didn’t resolve the issue.
I’ve been noticing similar figures for the past few weeks.
Has anyone with a FoxESS EQ4800 L9 experienced similar behaviour? Could this be an SOC calibration/BMS issue, or should I be concerned that there is a problem with the battery?
Any advice or suggestions on how to diagnose this would be appreciated.
Thanks!
Fox ESS KH10
Fox ESS EQ4800 L9
Sydney Australia
Re: Foxess 4800 L9 Battery or BMS issue
I have skim read your post, but you may want to check out this large thread here (about 80 posts) viewtopic.php?p=11713#p11713
tl;dr Fox claim that you can discharge to 0% in Australian market, reality is the software (at the time) would only allow 90% to be used (41.93kWh becomes available to use 37.74kWh) so that each 10% drop in SoC isn't 4.19kWh but 3.77kWh (when SoH = 100%)
It was a while ago, but you may have to check the maths.
MaterialBarracuda48 wrote: ↑Wed Oct 07, 2026 9:58 am I have skim read your post, but you may want to check out this large thread here (about 80 posts) viewtopic.php?p=11713#p11713
I will have a look.
Thank you
Fox ESS KH10
Fox ESS EQ4800 L9
Sydney Australia
Hi Sam,
If you take your new storage capacity of 41.09kWh @98% SoH and calculate, it's quite close I think.
41.09 kWh x 0.9 (to account for the 10% reserved) = 36.98 kWh 'available'
As you charged from 20% to 100%, the range is now 80% of the 'available' amount
So to take you from 20% to 100%, 36.98 kWh x 0.8 (difference between the %) = 29.58 kWh
Given that you input 28.8 kWh, the 2 figures are within margins of error. (at least to me)
I did see that you have tried to calibrate the battery, can you check what you did against Will's video?
Reason is, it might take a few cycles for the calibration to become more accurate.
https://www.youtube.com/watch?v=8LG1Jm5eWSs
