As part of our PV and battery system, we have the ESS EPS SP box fitted. What I would like is a dedicated, single socket in the house that will not lose power if the downstairs socket breaker is tripped. It will power my network equipment. Can a dedicated socket like this be wired into the ESS EPS?
Thanks,
Paul
8.82kW Array. 18 x Aiko Neostar 3S 490W panels. 14 S, 4 W facing. Fox ESS Evo 10, 10kWh storage with 10kW inverter. Fox ESS EPS 1PH Backup. Installed on 27th April 2026. Running ModBus via Elfin EW11a through Home Assistant.
Someone did post that the EPS SP box doesn't switch instantly IIRC, so not sure I would trust that with network equipment. Caveat would be if you have a small UPS that can cover the switchover process.
Hope the main part of your question can be answered by an expert.
