ESS EPS SP box dedicated socket
As part of our PV and battery system, we have the ESS EPS SP box fitted. What I would like is a dedicated, single socket in the house that will not lose power if the downstairs socket breaker is tripped. It will power my network equipment. Can a dedicated socket like this be wired into the ESS EPS?
Thanks,
Paul
8.82kW Array. 18 x Aiko Neostar 3S 490W panels. 14 S, 4 W facing. Fox ESS Evo 10, 10kWh storage with 10kW inverter. Fox ESS EPS 1PH Backup. Installed on 27th April 2026. Running ModBus via Elfin EW11a through Home Assistant.
Re: ESS EPS SP box dedicated socket
Someone did post that the EPS SP box doesn't switch instantly IIRC, so not sure I would trust that with network equipment. Caveat would be if you have a small UPS that can cover the switchover process.
Hope the main part of your question can be answered by an expert.
