As part of our PV and battery system, we have the ESS EPS SP box fitted. What I would like is a dedicated, single socket in the house that will not lose power if the downstairs socket breaker is tripped. It will power my network equipment. Can a dedicated socket like this be wired into the ESS EPS?
Thanks,
Paul
8.82kW Array. 18 x Aiko Neostar 3S 490W panels. 14 S, 4 W facing. Fox ESS Evo 10, 10kWh storage with 10kW inverter. Fox ESS EPS 1PH Backup. Installed on 27th April 2026. Running ModBus via Elfin EW11a through Home Assistant.
Someone did post that the EPS SP box doesn't switch instantly IIRC, so not sure I would trust that with network equipment. Caveat would be if you have a small UPS that can cover the switchover process.
Hope the main part of your question can be answered by an expert.
That was me who raised the slow EPS switch time and I now have a small UPS to fill that gap.
We're having the kitchen renovated and the sockets were switched off today and the UPS did admirably, laying just over 30 minutes. That's running a router, that's also doing the optical to ethernet conversion, an 8 port switch, with 2 SFP sockets and a single Deco mesh node. Quite impressive for a single 7.2Ah battery.
The sockets going off is what's sparked this enquiry.
So it was
I am not fully aware of the ins and outs of the box, my own setup has 2 sockets in the garage coming off the EPS port on the Inverter. That can draw from battery or solar if the Sun is up, but not really needed it.
I did want a similar setup to yours, bit the other paying towards it, didn't want the extra costs. I have a beefy Bluetti on some kit, and a one smaller UPS for router (not tested the run time, but in the past it was good for a few hours)
I was being lazy posting in all fairness. I just need to have a read and I'm sure it's capable of what I want.
