Title: New to Fox ESS – KH9.9 + EQ4800 in SA, a few setup questions
Hi everyone,
I've just moved into a rental in Mawson Lakes, SA that came with an existing Fox ESS system. I'm new to home batteries, so I'd really appreciate some help from people who know these systems.
My setup:
- Inverter: Fox ESS KH9.9 (single phase)
- Battery: EQ4800, 6 modules (about 28 kWh)
- Solar: about 10 kW
- Retailer: AGL Battery Rewards (26c/kWh feed-in from 5–9pm, 1c at other times; peak import 53c)
Current settings:
- Work mode: Self-use
- System SOC range: 10–100%, StormSafe Charging disabled
- Mode Scheduler: Forced Discharge 17:00–21:00, discharge power to grid 5000 W, cut-off SOC 30%, then Self-use, Discharge from PV on
- No Forced Charge periods, because I don't want to charge the battery from the grid
My questions:
1. Export limit: Quick Settings shows Export Limit 9.9 kW (greyed out, so I assume the installer set it). SA Power Networks says Flexible Exports is available at my address. How can I tell whether the system is actually on Flexible Exports or a fixed limit? Is it safe to raise the Forced Discharge power above 5000 W, or will the inverter enforce the network limit anyway?
2.If the logger goes offline, does the Mode Scheduler keep running on the inverter, and does it affect Flexible Exports?
3. Cut-off SOC: For anyone on a similar evening feed-in plan, what cut-off do you use to cover overnight usage until the solar picks up, without importing during the morning peak? In winter, do you raise the cut-off or turn off forced discharge on cloudy days?
Faz
Re: Title: New to Fox ESS – KH9.9 + EQ4800 in SA, a few setup questions
Hey! I’ve been there – the export limit is usually set by the installer in the firmware. If it’s greyed out you’re probably on a fixed 9.9 kW limit; the inverter will enforce that even if you bump the forced-discharge power up. The mode scheduler runs locally, so if the logger goes offline the inverter keeps following the schedule and won’t affect Flexible Exports. For overnight coverage I usually set the cut-off around 30–35 % SOC – it lets me use the battery until the sun comes back on without pulling from the grid in the morning peak; in winter or very cloudy days I raise it a bit higher or just turn off forced discharge to avoid draining too much.
I’ve had a similar set-up. The 9.9 kW export limit is hard-coded in the firmware – you can see it in the app under Quick Settings. Even if you set forced discharge to 10 kW the inverter will cap it at 9.9 kW. The scheduler is local, so it keeps running if the logger drops out. For overnight I usually set cut-off to 30 % SOC; in winter I bump it to 35 % or just disable forced discharge on very cloudy days to keep some buffer for the next morning. In my free time I also compare online casinos that are not subject to the German LUGAS system: https://casinoohnelugaslimit.de/
