Hi Everyone,
I noticed the FoxESS app has the Import Limit set to 9.2 kW (I tested it at 9.5 kW). When my house load increases, the inverter reduces battery charging to keep the total grid import below this limit.
My questions are:
Why was the Import Limit set to 9.2 kW?
Is this due to a FoxESS inverter limit, an electricity distributor (DNSP) requirement, or an installer setting?
My main switch is 63 A. Can the Import Limit be increased safely?
Is my house wired as whole-house backup, or are only essential/backup circuits connected through the inverter?
If the Import Limit is increased, will it affect the warranty or the approval from the electricity distributor?
Yes I had this as well. Set it to 12000w and my force charged had imprived a lot. I usually run about 18-20kw on free nevery days, so puzlled wht 9.2lw was a limit..
Most likely the default setting, you can safely raise the limit to 14000 watts, but you’ll also need to check in the inverter settings under export control that ImportLimitCurr is set to 63A (or higher).
