I am currently running the Cosy tariff, it appears when on forced charge as soon as I hit my charge target the battery starts running down to feed my consumption, as an example my force charge is set at 98% today my forced charge time was between 13:00 and 16:00, I checked the battery status at 15:00 and it was at 97% at 15:40 however the battery had already ran down to 75% and was discharging even though it should have been charging for another 20 minuets.
Any help with settings appreciated.
You want to set the value in red box to either 'Backup' or 'Standby' to have it hold the 100% SoC until the time period ends. Repeat this for the other Cosy schedules too (if needed)
I will explain what it does now, it charges during the time specified by you, once it reaches 100% it changes work mode to whatever is in the red box (probably 'Self-use') so this is why it begins to drain power before it reaches end of your schedule.
