Battery discharge issue - how to stop this.
Hi - I’m looking for advice please. I’ve set my battery to charge using cheap window of energy. I want it to then sit idle and discharge in the evening peak window, however immediately after it reaches the end of its charge window it starts to discharge to cover the house energy needs. Can anyone offer advice as to what settings I need to create please ? Thanks in advance :D
Re: Battery discharge issue - how to stop this.
Set another schedule item that follows your charge schedule with a workmode of ‘backup’ and end it when you want the battery to start powering the house when it returns toi ‘self-use’ - that will hold your batteries charge and use PV / grid during the day.
Thanks for that
I’ve set up a forced discharge’ window for 1600-1900 would that work with the setting you’ve suggested as well ? Sorry if I sound a bit of a idiot, I know it’s only a small battery but I’m trying to get the best use out of it :D o
It might start to drain before the new schedule still, if you have a charge set before 16:00 make sure to set the red section to 'backup'
If you are unsure, send a picture here of your set schedules.
