Fuse Tripping on Solar Panels
I have had the fuse trip a number of times over the last few months on the connection for the Solar panels I have had installed. I am not sure why its tripping but as its all in the garage the only way I know there is a problem is if I am in the App. Is there a way that I can get it to email me alerts that there is a problem or do any kind of automation from the inverter.
Thanks Bleddyn
Re: Fuse Tripping on Solar Panels
If you have home assistant you can alert if the inverter goes into fault mode, but just to ask is it an MCB or RCD that is failing, what size inverter do you have, and what is the breaker rated at ? - it sounds like either it the MSB has gone 'soft' or it needs to be replaced with something more suitable.
