Fox EQ4300 DP switch setting
Posted: Mon Jun 02, 2025 12:49 pm
by dellpitch
I am upgrading EQ4300 stack from one slave to 5 slave batteries but cannot find the DIP switch setting.
Any help much appreciated.
Re: Fox EQ4300 DP switch setting
Posted: Mon Jun 02, 2025 4:59 pm
by Will
normally 0 is 1 master and 1 slave, adding one dip per additional slave so 1 master and 6 slaves is 6 from memory.
On newer firmware, the dip can be left at 0 as the batteries are auto-assigning so don't be put off if it's already set at 0.
You'll know if you have the dip wrong as the bms is fault with a voltage error
Posted: Mon Jun 02, 2025 5:05 pm
by dellpitch
Will
Many thanks for the reply.
I will leave the DIP at "0" and watch the voltage.
Regards
dellpitch
Posted: Mon Jun 02, 2025 6:58 pm
by Will
Most welcome
