Off peak grid usage - Heat pump and EP11
Posted: Wed Jun 18, 2025 11:58 am
Hopefully getting a heatpump (5kw) installed in the next couple of months.
Currently I have a split 5.2kw solar array and an EP11. I mostly export as my electric use is covered by the solar and is well under the battery capacity on a daily basis. Considering that I will need to look at a further EP11 in due course but trying to figure how much of the daily heat pump usage can be offloaded to the off peak period without going to a Cosy like tariff
I have been exporting the remainder of the battery after midnight and then charging up ready for the day (Eon Next cheap rate 12-7am @ 6.7p)
So when the heat pump comes online I will need the heat pump to do the overnight hot water and an initial radiator heat up to ignore the battery overnight but then run off of the battery after 7am, but I can't figure the settings to do that? Is it feasible unless I drain the battery and then charge it as late as possible to finish at 7.
What is the order of operation when Mode Scheduler is set to Force Charge (Currently 2.30am to 5.30pm and then swapped to Feed in)? Does the battery try and power items while that is set or is it set to ignore self use for that period?
