Is Foxess AIO-H3 absolete/end of support?
Posted: Tue Jul 22, 2025 10:32 am
Hello. Half a year ago, I purchased an AIO-H3-10 with 4x HV2600 V2 batteries. Everything works more or less fine, but I would really like to get the new "Grid Pressure/Push Back" feature, and it would be great if the data display in the FoxESS Android app could be fixed. For example, while it's amusing to see that my modest 10 kW / 10 kWh system managed to charge 40 GWh and discharge 31 GWh in a single day, that's a bit too good to be true
Even if it's just a mistake in the units and "G" should actually be "k", the numbers still don't quite add up...
My current firmware versions are Master 1.33, Slave 1.00, Manager 1.37. Unfortunately, I can't find a newer firmware update for my inverter. Meanwhile, the H3 model receives regular updates. I'm starting to wonder if I bought a model that is no longer supported? Is there any possibility to install one of the H3 firmware versions on the AIO-H3?
