System issue following power cut
Posted: Wed Sep 03, 2025 7:49 pm
After a power cut earlier today I wanted to checked that the system was working properly. I attach a copy of a screenshot showing my system at 15.41 this afternoon.
The screenshot shows that there was a house load of over 7kw despite the fact that there was minimal electrical use in the house at that time. In an attempt to identify the cause of this anomaly I checked each fuse box switch in turn only to find that if I turned the solar off the electric usage went down to about 150watts.
I then re-booted the solar system to see if that would reset the system but instead it showed an even more bizarre reading as shown in the second screenshot. Here it shows that somehow the house was generating over 7kw which was being used to fill up the battery and some of which was being exported to the grid?????
Any thoughts.
Any thoughts.
