Negative CT Readings?
Posted: Mon Sep 08, 2025 4:33 pm
by Vini
My CT reading shows as negative, at a time when I'm drawing from the Grid. Is this expected, or is it because it's been incorrectly installed and the wiring is mixed up?
ie. Do I need to swap the pins in the CT header?
Image taken from Home Assistant after installing my Modbus adapter...
Re: Negative CT Readings?
Posted: Mon Sep 08, 2025 7:22 pm
It’s correct - the Grid CT sensor shows negative for import and positive for export - it is split into 2 further sensors feedin and gridconsumption both of which can only go from zero to a positive value.
Posted: Mon Sep 08, 2025 7:33 pm
by Vini
Magic, thanks 👍
