Adding correct batteries to H1 3.7 Hybrid Inverter.
Posted: Thu Sep 11, 2025 7:12 pm
by Icklegnome
Hi, I had a H1 Hybrid Inverter fitted as part of my solar panel install. I want to add my own batteries. I've seen a CM4300 for a good price, will it fit or is it now obsolete? Should I stick with ECM/ECS batteries
Re: Adding correct batteries to H1 3.7 Hybrid Inverter.
Posted: Fri Sep 12, 2025 3:02 pm
You would need to know the version and connector type on the CM4100 to be sure which is a bit of a minefield, You will also need a minimum of 1 master and 1 slave. I would say it was better to stick with ECM/ECS (V2), EQ or EPxx batteries - they are all readily available and upgradeable later if you choose to.
