DDSU666 install with H1 Hybrid
Posted: Thu Nov 06, 2025 5:06 pm
by mark@amgelectricalpembs.co.uk
I've installed this as far as I can see correctly
Are there any setting either on the Chint meter or within the inverter which need changing?
I called technical who updated the inverter but I still have issues.
With the batteries connected and switched on while no PV production the wattage level on the inverter screen raises slowly all the way up to 6000w before the inverter shuts down and restarts.
I need help!
Back on site tomorrow and will call every fox number under the sun to hopefully get some help if you guys can't help me by then
Re: DDSU666 install with H1 Hybrid
Posted: Thu Nov 06, 2025 5:47 pm
by Will
Just checking that you connected the meter to the correct ports on the com port and setup the meter as per the manual?
