String specific pv production
Is it possible to plot historic data of pv production specific for the individual strings, e.g. plot the kWh in a month for each string?
Would allow to assess shadow effect.
Re: String specific pv production
3 Possible ways I can think of
1. I think you can get this from OpenAPI viewtopic.php?p=3900#p3900
I will say that I have never used it, so could be wrong.
2. You can get daily figures for PV1, PV2 and so on strings via the Website: https://www.foxesscloud.com/v2/login
I can only see how to download 1 day at a time, so you would need to combine a month's worth of CSV data in a spreadsheet, also they are 5 minute snaps shots of a point in time, so not sure how it will add up?
You can also just view the daily data for each string to see if they follow each other, or if the pattern differs.
3. You setup HomeAssistant for better control/logging of raw data and present this, but takes effort.
Option 2 could be the easiest if you don't worry about the kWh values, but just wish to see a daily chart.
