FoxCloud2.0 on Android A52 Samsung not getting any notifications
Hi. Just wondering if anyone out there gets notifications pushed on their Android mobile from the FoxCloud2.0 app?
I get no notifications whatsoever. I have:
1. Uninstalled and re-installed the app
2. Cleared cache
3. Checked app settings to ensure allowed, etc etc
4. Set absolutely ALL notification types enabled in the app, just to be sure.
Anyone else had any trouble with this app on Android and/or Samsung mobiles? I guess my A52 is getting a little old by today's standards but it's nearly faultless with any other apps I use in terms of notifications, so it's pretty odd.
Keen to hear from anyone at all, even if they have no issues and get notifications. I might reach out to FoxESS support if it seems to only be me with this issue...
Cheers!
Re: FoxCloud2.0 on Android A52 Samsung not getting any notifications
I tried this on my phone for you, S23 Ultra.
When I turned on notifications (all) I got a message about the Cloud fault from the 11th. It kind of dissapeared before I could read any details though :D
I turned on a forced charge that should have created a pop up message, it didn't.
Given how duff the App has been lately, it is not a surprise.
Thanks MB48, appreciate the effort.
Funny you should mention the notification about the cloud page, I actually did get that too. It's only now I realise that it was a notification from the app, and yet no other notifications ever occur... And that's the first one I've ever seen.
So I guess they've got fairly major issues with their notifications within the app itself; I suppose I'll raise it directly with their support.
Thanks for your help
You are welcome, at least you know it is not your phone at fault.
CrazyGrayV8 wrote: ↑Fri Mar 13, 2026 12:22 pm So I guess they've got fairly major issues with their notifications within the app itself;
That's assuming they have actually coded their app/server to do more than just server outage notifications.
Although I'm speculating too as I usually disable most apps from being able to do notifications.
Interesting update for you, I just got a notification on my phone from FoxCloud2.0 App!
30% SoC was just reached.
Fun part, I have ALL notifications turned off now, since they didn't work the other day in testing :? :? :?
Notifications are all off, got low battery warning pop up :D
MaterialBarracuda48 wrote: ↑Sun Mar 15, 2026 10:39 pm Notifications are all off, got low battery warning pop up :D
I had that problem on an el cheapo Android tablet, if I used the switch at the top of the settings screen to disable them all the setting wouldn't stick.
What worked in the end was to turn off each notification category which was a pain as Facebook/messenger apps have lots of notification categories.
Go back and read the posts again, I have turned off in the FoxCloud2.0 App, all of the notifications, and I am now getting messages.
With notifications on, I don't get them, and I was just testing for OP.
I don't need any IT support.
Posting to show there must be some bugs in the App, matching what the OP is seeing also (lack of notifications) or being sent when turned off.
MaterialBarracuda48 wrote: ↑Sun Mar 15, 2026 11:49 pm Go back and read the posts again, I have turned off in the FoxCloud2.0 App, all of the notifications, and I am now getting messages.
Fair enough, I don't trust apps and do it in settings.
WTH?!? that's completely bizarre...maybe I'll turn mine off too now, and might finally some notifications come through!? :lol:
CrazyGrayV8 wrote: ↑Mon Mar 16, 2026 3:10 am
Yeah at this point you have nothing to loose, a win for software bugs.
It's bizarre for sure, though I will add I am only seeing the low battery warning come through :D
It doesn't pop up for charge/discharge events, but we did both get the cloud event notification.
After 2 days of low battery notifications, I was able to disarm the message.
Turned every notification on, pressed "back" button on my phone until I could see "Home" "Devices" "Me" at the bottom of the App, pressed "Home" and did a pull down screen refresh.
I then used the phones "back" button twice to exit.
Opened App, turned off all notifications and repeat the exit strategy above.
Last night the battery dropped under 30% SoC and I didn't get message this time. Running v2.2.4 currently.
So you seem to be able to get it to generate notifications and then - after some mucking around - not to generate notifications. Your android is a later model / more powerful Samsung than mine, but all other apps work fine generating notifications - or not - based on settings via Apps, etc.
I have mucked around a bit more turning some on, some off, rechecking, etc., etc., but nothing ever works. I raised as much in feedback on Google Play review, but it's unlikely to generate much interest from them, I imagine.
One thing I did notice whilst going through the settings is that the configuration of Notifications under the Me > System Settings > Notification menu list is that the "Alert Updates" appears to control all the notifications, but it's most odd from a user design perspective that it's under its own menu, given it changes values on menu 'levels' at the same level as it. So if you set Me > System Settings > Notification > Alert Updates > 'Notification push' to OFF, then toggles under Me > System Settings > Notification > 'Device Status' get turned off too. Like I said, that's not a normal approach to sensible UI design, IMO...
Doesn't help the issue, but anyhow....
It's a shame nothing worked for you, and as you say they are not likely to take the feedback and adjust what is broken.
Having the extra on/off toggle for notifications isn't the greatest either.
I can't seem to find any options for notifications. I'm in Australia and using v2. I would like to get push notifications somehow, so I can at least see an error messages.
(Today I think my young son turned off our battery unit and I didn't realize until about two hours later, when I just happened to look at the app and noticed something odd in the graphs... A pushed alert would have been great!)
If you're using the Android app it's under Me > System Settings > Notifications.
Turn everything on and see how you go, but don't hold your breath... Good luck!
CrazyGrayV8 wrote: ↑Sat Apr 11, 2026 10:05 pm If you're using the Android app it's under Me > System Settings > Notifications.
Thanks! Yes, I discovered it in Android app after posting :oops:
I though I had looked before but I must have just been looking at the web browser version.
