I just got my solar system set up yesterday and attempting to configure off peak charging from the grid (IOG).
When I create the schedule in the v2 app, it doesn’t appear to be charging at the time I’ve set.
However, if I disable the schedule mode (by selecting self use for example), then open the v1 app and navigate to the battery configuration screen, and set the charging from grid schedule; the battery then starts charging from the grid.
Has anyone experienced this before? Or am I doing something wrong here?
It is rather annoying that I need to switch back and forth between the apps and manually set this every time.
I have the EVO 10-5-H for reference. M
The FoxCloud2.0 App has a few bugs, and is missing the Grid Charge choice in the new version.
If you login here https://www.foxesscloud.com/v2/login and choose Quick Settings on top right you can program a grid charge timer. You may have to set two timers, 23:30 to 23:59 and 00:00 to 05:29.
There you can remove your scheduled charge that you input from the App.
There are other ways to get the same outcome if needed.
