whenever I open the app screen in windows (11) it is blank and needs a refresh or clicking the "X" on the dashboard tab
seems OK on Android
FOX KH7 7kw hybrid inverter
EN-EPS-BOX-SP gateway
are you using a bookmark with a long id in the url by mistake?
ummm...possibly
apologies, I am new to this I thought it would save me having to sign in every time.....
just using this https://www.foxesscloud.com/v2/login appears to work OK.... is that the link I should use?
I wouldn't deep link, you might be able to edit the url to remove any session id's that are causing the load issue.
OK, many thanks for the prompt reply
