Limit PV output+import
Posted: Thu Apr 02, 2026 1:34 pm
My install is in the garage which is fed from a switch fuse supply 40A taken from the main incomer with a 100A company fuse. I've realised that my house CU is rated at only 100A, but could see 140A as the garage and main incomer are effectively in parallel. Is is possible to configure the inverter so that using the CT on the incomer it ensures that the total is not more than 100A? (There isnt much space in the meter box for another switch fuse to protect the CU at 100A)
