Forced charge in mode scheduler is not charging from grid, only solar
Hello all
I have just had my fox system installed, so am new to all this, so bear with me.
I have been trying to use the mode scheduler to charge the battery overnight, with no success. So today I thought I'd add another schedule to force charge for 10 minutes, and noticed that it is charging the battery, but only from the solar (around 1kwh at the moment), with the house load being supplied by the grid.
How can I get the grid to also charge the battery too?
Re: Forced charge in mode scheduler is not charging from grid, only solar
There was a firmware bug that caused what you're describing. Ask your installer to update the firmware for your inverter to the latest.
Thanks for quick reply Will. I'll do that
