I have a T8-G3 inverter installation with 20+ solar panels and a Meter DTSU666.
In the IOS app, as well as the Fox ESS portal, the Load Consumption, Grid Imported and Grid Exported cards are always with zero, even when the immediate values as Grid Export (in the graph) shows values - see attached image.
I want to control and confirm not only the consumption but also the exported energy to the grid.
Why can't I get those accumulated values (day, month, ...)? Am I missing any other HW? Is that a configuration/installation problem? I have seen the app dashboards (with a FOX ESS KH10 inverter) and all those values and counters are there with the right values.
Sadly the solar only inverters other than real time values and graphs don't record statistics for daily, weekly etc.. on load, grid consumption, Feed in etc.. - Fox have confirmed that only Hybrid inverters store long term statistics.
More information here on the home assistant cloud discussions https://github.com/macxq/foxess-ha/issues/260
If you have a home assistant using the cloud interface you will be able to use that instead to record the statistics
Hi Dave, thanks for your reply - that post you referred is about the same thing. This is really strange how a system like this one can measure the instant and not the cumulative FeedIn (as it does with the Solar Power).
I have a Home Assistant Green and I'm trying to have that calculated somehow - like a table "Day 1 - ∑FeedIn; Day 2 - ∑FeedIn" so I can control how much power I'm selling to the grid. No luck till now.
Maybe I will need a Shelly or similar to have this. The support has suggested to have a "FoxESS Chint Gateway" because of nights (when the inverter goes off) but with all these news I'm not sure it will make it better.
Thanks in advance
Thanks in advance
