Max Export Power on Inverter keeps resetting to 00002
Posted: Thu Jun 11, 2026 11:10 am
There is an existing topic about forced discharge not working. I have now got to the bottom of this with the help of other contributors and the problem is that the inverter maximum export power keeps resetting.
It seems to last one or perhaps 2 days, but then I notice the forced discharge (although set up properly in app) has stopped actually discharging. I go to the Inverter, check the settings and it has reverted to 00002W again.
As highlighted on the other topic, the installer of my ~20kwh battery, did not apply for G99, so I only have G98 (2680kw) I have now found someone who has aplied for G99, so I should get a higher export limit.
I was wondering if the grid/DNO could have reset my inverter, but it seems to happen whether I have 2680 or a higher value.
As of now I do a small forced discharge (30 mins) to happen before I wake up, then if its stopped working again I'll go down to my basement and reset the max export level on the inverter.
If anyone has any ideas please let me know. The battery is set to never go below 10% so its not that.
I'll keep on with this and Ill see if when I get G99 it stops. Obviously this is not ideal for if I go on holiday for example.
I spoke to Octopus and they said they dont monitor the export limit, they just pay for what they get.
James
James
