I've just had a system installed and very happy with it.
I've recently gone over to Octopus Agile and I've connected the API to the FOX app.
When I set a schedule to buy electric triggered by price (e.g. 2p) it accepts the price for that day but when it goes over to the following day it adjusts the price to a random number (e.g. 23.3p)
I presume it does this because the min price changes daily but I want it to charge the battery at set price regardless of the day's prices. For example, set the price at 2p and whenever it hits 2p it charges the battery, whether it hits 2p tomorrow or in 4 weeks time. A "set and forget" type of schedule.
I don't know if this is possible but it makes logical sense as you can always charge at the price you like. People don't want to be checking prices every day and setting a schedule for that day?
Any help is much appreciated.
Sorry to post on my own thread.
Mode Scheduler doesn't seem to be working. It works if it switches to a "standard mode" i.e. peak shaving but it won't switch to force discharge or force charge.
As a result Octopus Agile doesn't work at all.
Anyone got any idea as to why this would happen?
Could you go through the process of setting up mode schedule again and just check that you've hit every Confirm, Save and Apply that appears? I've been caught out by that before.
H1 5.0 E G2 inverter
EP11 battery
3680W solar 8 panels
EP11 battery
Thanks so much for your reply.
I tried again making sure I've hit every OK and confirm etc. Still no luck.
It successfully works on self-use and backup but not force charge or discharge. So it seems as though it scheduler is working but the force charge or discharge modes are not.
I did test Agile again a week ago, seemed fine.
Can you post screenshot of your Agile mode settings, so it can be checked?
Screenshots attached. As you can see the current mode is "forced charge" so the schedule from Agile is working as it should but the inverter isn't pulling 1000w from the grid.
The inverter is working as it would in "self-use" mode not "forced charge" mode
I asked for 3x slots, and I have it set as you to get the 3x cheapest slots for the day.
When I exit, and enter the Agile section again, I get 3x charge sessions populated.
Maybe your power rate is too low, and I am not sure you need 14x charging sessions.
If you don't see the charge slots listed after setting, you may have to delete your tariff and load it again perhaps?
The Inverter firmware could be interpreting this as not to pull 1000W from the grid, but operate the Inverter in "make 1000W of power in total"
I set 14 slots to try and get it to charge at the current time. I've tried many different W amounts. Everything from 10W up to 13000W.
I think this is going to be more complicated than I ever could imagine. This person has the same inverter as me and he has his hard wired and running code etc and still has issues:
viewtopic.php?t=3422
Hello Gogetta and All,
Gogetta, this is the exact issue I have, I've checked and checked, deleted and reinserted my API code yet come midnight the price to Import energy jumps from, as you said 2p up to a random cost say 23.3p.
Everything else seems to be correctly set up it's only the import (I've not set export as yet) settings that randomly change.
Did you find out why this was happening and find a solution to this issue?
Does anyone have the solution to this issue?
Many thanks
Stevie
Fox ESS
K8- 11.52 battery
Octopus Agile import and export
Many thanks
Stevie
Fox ESS
K8- 11.52 battery
Hi Birkenside4
I no longer use Agile so I can't comment at the moment but last time I tried I had the same issue as you.
The only thing I can suggest is that you make sure you're on the latest firmware. If that doesn't work then I guess we need to wait for Fox to sort this issue.
I thought the same as you, I presumed once a price is set then it will charge at that price indefinitely. It makes sense to me that that's how it would work. Why would one want to set a price just for the price to change the following day?
Hi Gogetta,
Thank you for your reply, If that one setting could be fixed/changed the system would be perfect for me.
Good luck
Stevie
Good luck
Stevie
