Import Limit / Peak Shaving independent of Work Mode (Predbat compatibility) - H1-G2
Posted: Fri Jul 24, 2026 10:04 am
On the FoxESS H1-5.0-E1-G2-WL (H1-G2), setting 'Import Limit' in the app automatically switches the inverter's Work Mode to 'Peak Shaving'. I'm running Predbat (via Modbus/Home Assistant) for price-based charge/discharge scheduling, which also controls the Work Mode entity (Self Use / Force Charge). Is the Import Limit / grid import cap (ImportLimitPower) available as an independent Modbus register that can be set without switching the Work Mode to Peak Shaving, so it can run alongside an external scheduler like Predbat?"
thanks in advance
thanks in advance
