First of all can I say thanks for help already given. I seem to be having an issue where ev charging and battery charging can not happen at the same time. The EV charges for typically 2 hours and when that battery is full the home battery charges for a few hours. Any thoughts. Reading around I think it may have something to do with how thwe EV charging is being monitored but am not sure I understand it completely. Thanks in advance.
Re: EV and forced charge interfering?
Posted: Sat Nov 28, 2026 3:46 pm
by MaterialBarracuda48
Typically the CT clamp for your inverter measures your entire house load, if your EV charger load is seen and calculated by the Fox CT clamp, then it will throttle depending on the limits.
Open Fox App, Quick Launch and you should see Import limit on this screen.
If it is too low, then it will throttle back if it sees the load of the EVCP.
So if your Fox import limit is set to say 8kW, and your typical EVCP is 7kW, then this means your inverter will throttle back and only allow 1kW of import power.
Posted: Sat Nov 28, 2026 5:14 pm
by DavidAllanCowan
Seems likely this is what's happening. How do I fix it. I don't think my installer is still talking to me? And it seems he has control over it (which is disturbing.)
Posted: Sat Nov 28, 2026 5:25 pm
DavidAllanCowan wrote: ↑Sat Nov 28, 2026 5:14 pm
You can adjust it direct on the inverter controls, can you say what import value you see now?
Look here and you will see the Import and Export limits, leave Export alone.
My Import is set to 18,400 Watts, as I have 80Amp house fuse for reference (80A x 230V)
p.s. The installer control of the system is normal.
Posted: Sat Nov 28, 2026 5:43 pm
by DavidAllanCowan
Thank you so much. Will do it first thing tomorrow (when it might not be raining!).
Posted: Sat Nov 28, 2026 6:38 pm
DavidAllanCowan wrote: ↑Sat Nov 28, 2026 5:43 pm
What is the current Import value set to, just wondering (and helps others that read your thread)
