I am currently experiencing an issue with the CT, which has stopped charging my battery entirely. I’ve been informed that it will take at least a week to have it repaired. In the meantime, I’m trying to determine if there is any temporary configuration that would allow the battery to charge.
When the system is set to Self-Use mode, it only generate enough power(0.400KWh) for household consumption only even it clear sky.
When it is set to Feed-in mode, the PV output reaches maximum(Upto 10KWh), but in both modes, the battery does not charge.
Below are the configurations I have tested and their corresponding results:
Current Battery Capacity: 50%
Case 1
Mode: Self-Use
Min-SOC: 20%
Min-SOC (Grid): 20%
Force Charge: 10:00 – 15:00
Charge from Grid: False
Result:
PV Output: 0 kW
Battery Charging: 0 kW
Household Load: Drawing power from the grid
Case 2
Mode: Feed-in
Min-SOC: 20%
Min-SOC (Grid): 20%
Result:
PV Output: 0.40 kW
Battery Charging: 0.40 kW
Could you please advise if there are any alternative settings or temporary configurations that would allow the battery to charge until the CT is repaired?
