Home Assistant modbus connection - source and install pins
Hi following this guide and removed meter/ct/rs 485 connector (16 pins on a kh inverter). Ready to add my two connections from the adapter to pins 3 and 4. Guide says to use red 2 cm connectors left by installer. There aren’t any. Has anyone sourced these say on eBay (link would be great) and how are they fixed to the two wires? Push fit or crimp perhaps. Nearly there once I can get these added.
Many thanks
Re: Home Assistant modbus connection - source and install pins
After more searching found that they are red bootlace crimp. Various sources including eBay. Also see that a crimp tool is required or can be done using pliers carefully
