Login via IP Address Smart Network Configuration
Hi All,
New to this forum, juts got my FoxESS H3 15 Smart Inverter installed with 42kw battery.
I tried to access the inverter via the IP address assigned by my router i.e. https://192.168.x.x/
The site says Smart Network Configuration and there is a default user already pre-filled "admin". Just wondering what is the default password? I tried all the common ones like mtm2022 0000 12345678 etc. but they all don't work.
Does anyone know what happens after login? What is this for?
Re: Login via IP Address Smart Network Configuration
This is the datalogger access and it is used to connect the inverter to the Fox cloud and not for local connection to your computer/app so all you can do here is configure the wifi connection which should have already been done by your installer. If you can see the inverter in the app / Fox cloud then it’s already connected.
Hi Dave,
Thanks for the reply. I was trying to see if there are anything else I can do besides using FoxESS cloud for HA intergration. Many thanks.
If you want to do local control using home assistant (or similar) you'll need a modbus connection - lots of info here about that https://github.com/nathanmarlor/foxess_ ... ring-Guide
With the modbus you get much finer control over what and when the inverter does things, and it also removes the reliance on the Fox cloud and whilst generally it is reliable, it does have occasional issues (normally sorted within a few hours).
