Latest firmware for H1-3.7-E-G2?
Apologies if this has been already posted. I have had a look but I'm a bit new to this and not 100% sure.... of anything, really!
I have recently had my 9-month old H1-3.7-E-G2 inverter replaced with a new one after the old one fried its mind when I had the battery upgraded. (Fox said they'd never come across the error codes it threw up before, but that's another story.)
I just wondered if the firmware on the new inverter was up to date, and would be very grateful for any help. Currently, it reads:
Version_Master:1.33
Version_Slave:1.03
Version_ARM:1.49
Thanks.
H1-3.7-G2
Version_Master 1.51
Version_Slave 1.03
Version_ARM 1.66
EP12 Plus
Version_BMS: 1.012
10 x 4.10 PV
8kw Heat Pump
Re: Latest firmware for H1-3.7-E-G2?
Reading Will's sticky post above, it looks like these are the value...
viewtopic.php?t=1927
24/11/2025 Inverter H1 Gen2 Master 1.47 Production (Latest)
21/09/2025 Inverter H1 Gen2 Slave 1.04 Production (Latest)
24/11/2025 Inverter H1 Gen2 Manager 1.64 Production (Latest)
I should have spotted that sticky post. (Schoolboy error!)
Many thanks for being kind and patient.
The installers said it had the latest firmware when they fitted it (three weeks ago), so I shall contact them and ask them to update it.
Thanks again.
H1-3.7-G2
Version_Master 1.51
Version_Slave 1.03
Version_ARM 1.66
EP12 Plus
Version_BMS: 1.012
10 x 4.10 PV
8kw Heat Pump
We all have our Mr Magoo moments :)
Skip the installers, and go directly I would say... UK Support email here
"service.uk@fox-ess.com" <service.uk@fox-ess.com>
Ask them to please upgrade your inverter, and supply the Inverter serial number with your email
Thanks again.
Mr Magoo moments seem to have been a central component of my life, and seem to be on the increase as I get older! :D
It's a great source of comfort to know that there is so much friendly advice and knowledge available in this community though, and I shall gratefully take your advice and send the email today.
H1-3.7-G2
Version_Master 1.51
Version_Slave 1.03
Version_ARM 1.66
EP12 Plus
Version_BMS: 1.012
10 x 4.10 PV
8kw Heat Pump
I am glad you got the reference, let's hope that Fox can sort you with some fresh firmware updates.
Shame the installer said there was none available, self-support is the way forward for you.
