Ground Fault
I have today moved my inverter to allow the fitting of an additional slave battery, in doing so I broke the earth connection, where the earth from inverter, battery join the earth connection to the main earth point.
The inverter is now showing "ground fault" which I cannot clear, all other readings seem to be normal.
Thoughts please as to how I rectify the error!
System is EQ4300, the new battery when fitted will bring the batteries up to the maximum.
Re: Ground Fault
Your post is not 100% clear.
Have you fixed the broken Earth connection wires, and the fault remains?
