Scheduler Help
https://ibb.co/Lh6f1Zyx
I’m sure this is correct but need sanity check.
Is this the correct way to stop battery dropping during these hours.
Trying to stop battery drain when charging my EV on off peak.
Don’t trust the current Fox app as it does not switch off the scheduler properly.
Re: Scheduler Help
So.
Even though I saved and deactivated this schedule it still changed the min Soc to 80% and left it there.
So when I checked. my house battery was being charged. (It was at 76%)
I have to manually change min soc back to 20%
So…I presume if I do this, I need another schedule to set it all back to my normal.
Oh my days. lol
Re: Scheduler Help
Yes that’s correct minsoc (uniquely) is left at it’s previous setting in the last schedule, you need to set a short self use schedule for say 5 minutes to return it it’s normal level after any schedule that has modified it.
