I have noticed that the portal and app are registering my PV4 input power lower than actual
The voltage and current values are correct in the display, but the maths register about 30-40% less
137.8*11.9 should equal 1640w
All other inputs display correctly.
When I look at the physical inverter, the PV4 input power shows correctly.
Which inverter model is this? Possible you're hitting the limit for total PV power?
I have a 10kw KH inverter, so it's not clipping. I see the discrepancy across all power ranges, whether is generating 3kw or 10kw.
As stated in the original message, the inverters LCD display shows correct power output for PV4. So it's only a website display issue.
Just wondering if anyone else with 4 PV inputs is seeing something similar.
