Feed In Priority
Why am I getting an error code: "44096-Unsupported function code" when I try to enable Feed In Priority?
Inverter: H1-5.0-E-G2-WL Version_Master:1.51 Version_Slave:1.04 Version_ARM:1.35
Battery: EP12 Version_BMS:1.011
Or am I getting a bit ahead of myself in trying to enable this function?
Best regards,
Derrick
Re: Feed In Priority
You probably have a schedule setup, or grid charge enabled.
Turn off these and try the change.
Yes the 44096 error is an unfriendly way of saying that the scheduler is enabled and that stops you making workmode and soc changes - disable scheduler to change the workmode.
Many thanks for the helpful replies.
Is there any possibility that someone, in a position to do so, might feed back to Fox that a friendly and informative message might help to reduce the tendency to panic?
Best regards,
Derrick.
Post a message here Derrick,
Feature Requests
viewforum.php?f=51
Will has some contacts at Fox, and I think one of the Fox UK team visits the site.
It would actually reduce panic/tickets being made if they just wrote up some better error messages.
Error 44096:
"Please check that you do not have a schedule enabled at this time"
