I have an H1 G2 5kW inverter coupled with an ECS2900 energy cube and recently added an additional slave battery to the existing 2 slaves in place. I have two charge periods set for the winter months: 1 to charge up during the 2am-5am Octopus economy slot and another between 3pm-4pm to cover off the expensive tea-time tariff.
Everything worked fine for about 4 days and then I noticed that I was drawing from the grid at 7am, which shouldn't happen. The inverter is charging the batteries but is limiting the current to 5A - the max charge setting in the inverter is 40A - so the battery is only partially charged when the charge period ends. For the few days that everything was fine, I didn't check the charge current specifically, but the charge load was 5kW (compared to the 1kW I see now) so more than 20A.
I've seen comments that charge current is reduced when it's cold - less than 5c I think - and it's certainly warmer than that in the attic. The FoxCloud app says the battery is 11.9c and Home Assistant shows a battery temp of 23c (I think this is maybe the cell temp?).
I've tried removing the new battery pack but it made no difference so I put it back on. The new pack is an EQ2900 which Fox list as compatible with the EC2900s I already had. There's no big sticker saying V2 Type A like on the older packs but the supplier has assured me that it' compatible and I've seen references to the EQ series being type A only.
Anyway I've written too much already. No errors, red lights or other indication that anything is wrong apart from the charge current not exceeding 5A for nearly a week now. Am I missing something simple or do I need to call my installer?
You need to be looking at the bms mincell temp not the battery temp as that is the bms which is normally warm. The bms charge limits are set from the mincell temp value. Anything under 12c will start limiting the charge rate.
Use the foxcloud2 to report on your mincell temp as I show here:
Aha! Since Wednesday, which is when I noticed that the battery wasn't charging fully, the min cell temp has been consistently below 12ºC during my charge periods. I'll stop worrying now.
Thank you.
Thank you.
yeh, it continues to derate down to low single figures when the battery stops responding.
