Hello!
I have KH 10.5 with a full stack of ECS4800 batteries at the following versions:
Master 1.41
Slave 1.01
Manager 1.37
BMS 1.013
Also have three strings of solar panels.
I use a modbus connection to home assistant where I do all my tweaking and automations, so that being reliable is important to me. It has been!
I run whole house off of EPS output, have a ground rod. Only car charger is off a henley block and not seen by inverter.
As discussed in another post, I have managed to be able to switch my grid connection over to be fed from a generator for emergencies. This required no relaxing of safety settings. Licensed electrician consulted on my plans and did the work and signed off on it.
I feel that since we now get change logs from FoxESS I can decide for myself going forward, once I'm up-to-date, when I want to update. But right now everything is working pretty well so I'm just checking in to see if any expert on here (especially one who has KH like jedi master William Eccles) if there are still any quirks that are better on my old firware than on what I would receive if I request an update today. Any nagging issues that would make you advise me to stick to what I have until something gets sorted out???
Thanks for any insights!
