Mobile App V2.2.0 Mode Scheduler On/Off Toggle Switch Missing
In the previous version of the mobile app, and the current version of the web interface, there was a simple on/off toggle to enable or disable a schedule without deleting it. I can't seem to find it in this latest version and when the update happened it deleted my schedules that were toggled off at the time. I used this feature to make it easier to enable or disable force charge or force discharge schedules according to the battery SOC or Octopus saving session etc.
It seems that any schedule that is not used daily has now to be deleted rather than toggled off and recreated a day or two later when it is needed. Am I missing something?
H3 Pro 15.0 Inverter (Master 1.74, Slave 1.06, Manager 1.39)
3 x EP11 (ver 1.08)
40 x 430w (3 arrays)
2 x Baxi Heatpumps
FoxCloud 2 Android V2.2.0
Re: Mobile App V2.2.0 Mode Scheduler On/Off Toggle Switch Missing
Yes, the same issue for me. I'd toggle schedules on and off depending on weather, Octopus free sessions, etc.
Also lost my export schedule as it was toggled off at the time of the update.
Hopefully the toggle can be reinstated (or is there a work around?), as having to delete/re-enter a schedule each day depending on needs will be a real pain!
BTW, had to use the new slider within my Force Charge schedules to up the max SoC from the default 10% to my normal 90%. I couldn't understand why it wasn't charging before spotting that... I've also tweaked the Charge Power from Grid settings as they also didn't carry across from the previous version.
James S.
Thanks for confirming it's not just me. I set a force discharge and had to carefully check the limits. It seems crazy that the only option is to delete a schedule then set it up again a few days later! The toggles are still available in the web interface, but I haven't tried using them yet. Also missing the sunrise/sunset times on the main screen and the tariff revenue bit seems way off, but that may have been like it before.
3 x EP11 (ver 1.08)
2 x Baxi Heatpumps
So many little issues like this as well as the UI in general... It's not a great update imo.
Going to the graphs... Was swipe right... Now scroll down to a different section and click a small arrow on 1 of 3 sections
Graphing... Can't see all the graphs together, just one at a time. Battery and Grid seems doubled up imo
Quick settings... Just not as intuitive tbh but the ability to scroll round minutes is good
