Work Mode Min Max SOC v2.2.0
Where can I change the Min and Max SOC settings for each work mode with the new v2.2.0 app?
Thanks.
Re: Work Mode Min Max SOC v2.2.0
You have two options
S-love-nia
@fumbo Thanks for the quick reply but it's not clear from those screenshots how they relate to each scheduled work mode.
I have 2 scheduled work modes with different SOC settings which I set using the previous app.
I imagine the battery control settings immediately under Quick Settings relate to the current running work mode?
How would I edit these settings for a different scheduled work mode?
Perhaps the whole scheme has changed and now we can no longer have per schedule SOC settings?
Hope that was clear,
Thanks.
Mykey wrote: ↑Mon Feb 09, 2026 11:11 am
Yes you are correct, the scheduler no longer allows per schedule soc settings - you can have the system defaults, and Force Charge/Discharge have their own cut off soc’s (assuming does ‘Backup’) but Self Use and Feed In First can only use the default settings.
That's a shame but thanks for the response.
Looks like I'll have to come up with another scheme to get the results I'd like.
What I'd like to achieve is pretty typical:
1. Force charge the battery to 100% when it's cheap between 2am & 5am (Octopus flux)
2. Between 5am and 3pm I'd like the house to use some power from the battery but reserve 75% of it for the peak time. The solar can be used to charge the battery back to 100% if available during this time.
3. Between 3pm and 7pm allow the battery to cover the house load.
Any advice appreciated.
Mike.
I had the same problem in the APP. I was following a similar charge pattern to yours.
Have a look at the desktop though, you can still add force charge and self use schedules each with a minimum battery SOC (rather than the single floor value if you opt for the default to self use in APP). The toggle on off also is there and works for me, I have turned off the 24 hour self use window for now.
I've deleted the v2.2.0 APP for now as I was finding it was writing old (hidden in the APP data?) values and forcing the reserve SOC up to 80% every time I opened it, which was then stopping the battery discharging at peak periods.
Do keep a close eye on transition of schedules, as I said I removed the APP as it seemed to be rewriting unwanted values into the inverter/BMS software..
I think we need to explain the new features of the new app in one video. Is that possible? Thanks and all the best
S-love-nia
Maybe you can solve your problem directly in the inverter settings.
S-love-nia
