Shelly Pro 3EM cannot be added as smart meter in FoxCloud 2.0 (Avocado 22 Pro) – error when saving
Hi everyone,
I am trying to integrate a Shelly Pro 3EM as a smart meter into my Avocado 22 Pro system via the FoxCloud 2.0 app. Although the Shelly Pro 3EM can be selected in the app, I get an error message when I try to save the configuration (see screenshot).
Here is what I have already checked:
Both devices are in the same subnet (192.168.178.xxx), the Shelly is reachable via its web interface.
Modbus TCP is enabled on the Shelly on port 502.
Authentication on the Shelly is disabled (no local password).
Shelly Cloud is active and the device is online there.
Firmware of all devices is up to date.
Question:
Has anyone successfully set up this combination (Shelly Pro 3EM + Avocado 22 Pro + FoxCloud 2.0) and can tell me which exact settings are required in the app and/or on the Shelly so that the integration works without errors?
Image[/img][/img][/img]
Re: Shelly Pro 3EM cannot be added as smart meter in FoxCloud 2.0 (Avocado 22 Pro) – error when saving
I have exactly the same setup and had the same problem today.
After long debugging with tcpdump on the WiFi access point, I found two issues:
The first seems to be that the Shelly Pro 3EM (gen 2, version 1.7.1) does not send mDNS properly when connected to WiFi.
After connecting it with a LAN cable, mDNS broadcasts were sent correctly.
The other thing (which might have been the main issue: I only have one phase at home and so I set my Shelly to monophase. Well.. The Avocado has a hard coded URI which it tries to poll:
http://<your_shelly_ip>/rpc/EM.GetStatus?id=0
Unfortunately this is delivering a 404 when set to monophase, because the correct URI then is
http://<your_shelly_ip>/rpc/EM1.GetStatus?id=0
(which does not match the hardcoded one.)
→ So set it back to triphase even if you only use one phase.
After these two things (LAN+triphase) the Avocado was able to connect to the Shelly.
I could then even remove the LAN cable and it still works over WiFi. Let's see if that stays stable. 😅
Oh and maybe you want to check your WiFi that client isolation is turned off.
Hope that helps. :)
P.S.: If a developer is reading this, you can get the device info with the URI
http://<your_shelly_ip>/rpc/Shelly.GetDeviceInfo
and the capabilities with
http://<your_shelly_ip>/rpc/Shelly.GetComponents
(regardless if the device is in mono- or triphase).
The first URI also returns the current profile and you could derive the correct path to be used (see above).
hey thanks for the information, but i dont really know what to do. can u post step by step guide?
this issue sucks an no one from foxess give a shit...
thx in advance.
Condensed from my longer post (not sure if there's an easier way, but this worked for me):
  • Disable Client isolation in your WiFi (if applicable)
  • Connect your Shelly Pro 3EM with a LAN cable and configure the IP address in the Web GUI of the Shelly
  • Set your Shelly to triphase (should be the default), monophase is due to the wrong hard coded URI not working
  • Connection in the app should work now (close and re-open the app after each try)
  • If it still fails, you could disable WiFi in the Shelly and only use the wired connection to mitigate the mDNS bug
  • If it still fails: I found the information, that disable and enable of Settings → Eco mode (in Shelly GUI) triggers an mDNS broadcast. You could try toggling that during your connection attempt in the app (the 10 second timer), maybe the it's being received at the right moment and allows a successful connection
  • After the Shelly has been connected to the Avocado, it still worked after disconnecting the LAN cable and only use WiFi (enable WiFi before you disconnect the LAN cable)
⚠️ The FoxCloud 2.0 App got a bigger update recently, I set this up in the prior version, so it might have changed.
Really annoying, but I hope that helps.
Best regards
