Re: Option to schedule charging disappeared
hi
ok so I currently have a Forced charge schedule set up for over night cheap rate between 01:00 - 05:25. Do I add another window and set that from 05:30 - say 21:00 ?
rolotwix12 wrote: Tue Mar 03, 2026 12:01 pm ok so I currently have a Forced charge schedule set up for over night cheap rate between 01:00 - 05:25. Do I add another window and set that from 05:30 - say 21:00 ?
The app/website now seem to have a default mode for when no schedules are explicitly set, so you just need to add schedules when you want the battery to do something other then the default setting.
If you only want them sometimes, just disable them and re-enable when you want to do it again, the site/API seems to have a 100 schedule limit, so add away to your hearts content.
Thanks.
Just wondering though in the schedule for Forced charge, I don't want the battery to charge from the Grid during the day when producing Solar energy, so how do I set the schedule up. I want the system to charge from Solar energy during the day upto 90%.
I have a schedule set as follows, this one I need to have batteries charge from Solar only upto 90%
Forced Charge 05:30 - 23:00
Charging Cut off - 90%
Charge power from Grid-0.00w
Charging from Grid - Disabled
Status -Disabled.
And another Schedule set as follows which makes sense to use cheap rate electric to charge batteries if required.
Forced Charge 01:00 - 05:25
Charging Cut off - 65%
Charge power from Grid-10500.00w
Status -Disabled.
