new joiner in Dorset with EVO 10 AIO
new member here just want to say hello.
New ESS EVO 10 AIO
No PV
ZAPPI car charger
I have some questions that i am hoping to get help with but i'll raise them in the correct forum area :)
Re: new joiner in Dorset with EVO 10 AIO
I must say the AIO's do look much neater than normal installs.
I guess they come with heating as a choice?
MaterialBarracuda48 wrote: Wed Mar 04, 2026 8:24 pm I must say the AIO's do look much neater than normal installs.
Heating is included as standard AFAIK.
MattyS wrote: Fri Mar 06, 2026 5:46 pm Heating is included as standard AFAIK.
That should help them in the Winter, I was not 100% they came with heater, but good to hear they should.
MattyS wrote: Fri Mar 06, 2026 5:46 pm 7 ESE, 8 WNW
I'm curious to know how much sun does the panels facing WNW get?
evilbunny wrote: Sat Mar 07, 2026 1:19 am
I will update you when its installed! the projected kWh per annum is 3354. Although I'm fully aware thats just projection
MattyS wrote: Sat Mar 07, 2026 9:29 am I will update you when its installed! the projected kWh per annum is 3354. Although I'm fully aware thats just projection
How/where did you get that projection because aren't they facing away from the sun in the northern hemisphere?
evilbunny wrote: Sat Mar 07, 2026 10:27 am
I got it from Solarazma which gets data from PVGIS https://joint-research-centre.ec.europa ... m-pvgis_en
MattyS wrote: Sat Mar 07, 2026 10:50 am I got it from Solarazma which gets data from PVGIS https://joint-research-centre.ec.europa ... m-pvgis_en
Thanks for the link.
When I entered ours systems, it estimated June being less than July by 10-15% even though we get less solar in July.
