About a month ago I set the batteries to charge from grid between 3am and 5am. I now want to switch this off as Solar is producing enough for me. However, it seems the app has changed and I can not find the toggle anymore. I have read many of the forums with similar topic and have learnt how to schedule a "forced charge". However, this does not tell me how to switch the old schedule (pre new App) to switch off! Anyone out there who has solved this? Many thanks
You'll need to use the desktop version to disable this old charging slots and use mode scheduler going forward.
Thanks for the prompt reply Will.
So I am using desktop and it seems the same as the app. There was no scheduled battery charging to see. I am very conscious that I may be in the wrong area (I had to go to the "new version available button" to even see any battery setting info by the way). Im doing something wrong, can you give me more help please?
Im very grateful for your time.
Sorry, one image shows that I have newly added a scheduled battery charge just to see if by toggling on and off it will override the original timed charge.
"Grid Charging Time" at the top of the quick settings is where you find the basic timed charge.
