Just curious- EVO10 H How does it drain water?
So, as the title says I'm very curious how the EVO drains water.
Its IP66 rated, so ok for outside and mine is on the front of my house. Its just rained very hard and it got me thinking, if water gets in the vents at the top, where does it exit? there don't seem to be any specific drainage points that I can see?
Thaks
