Hi all
My HA integration has been working without issue but the last few days I just get a connection error and all values say unknown. This is the error it shows:
Error connecting to inverter (friendly name: ""). Error reading registers. Type: RegisterType.HOLDING; start: 31000; count: 43; slave: 247 from /dev/ttyACM0: Modbus Error: [Input/Output] No Response received from the remote slave/Unable to decode response
Does anyone know a fix for this?
Usual quick checks
1. Broken wire(s)
2. Inverter needs restarting
3. HA needs restarting
If that doesn't make it work, then check the finer details on settings.
1. Broken wire(s)
I've tried those things and still get the same issue. I've not changed any of the settings so not sure why they'd effect it?MaterialBarracuda48 wrote: ↑Thu May 07, 2026 10:18 am Usual quick checks
1. Broken wire(s)
What type of inverter ?Willzs wrote: ↑Wed May 06, 2026 9:25 pm Hi all
I experienced the same with H3 version 2.23/1.93
It's a KH8 inverter. What was the fix for yours?rpdasd wrote: ↑Fri May 08, 2026 9:11 amWhat type of inverter ?Willzs wrote: ↑Wed May 06, 2026 9:25 pm Hi all
1.60 master, 1.02 slave, 1.58 manager
Nothing yet. I think the modbus table changed or the modbus protocol? frame?.Willzs wrote: ↑Fri May 08, 2026 9:12 amIt's a KH8 inverter. What was the fix for yours?rpdasd wrote: ↑Fri May 08, 2026 9:11 amWhat type of inverter ?Willzs wrote: ↑Wed May 06, 2026 9:25 pm Hi all
I updated the inverter and HA on the same day, so many variables :\
possible to reverse-engineer the new table, but "aint nobody got time for that"Willzs wrote: ↑Fri May 08, 2026 9:32 amThat's what I'm thinking mine is as it was fine before. I've emailed fox and asked the question.
